Hi Timothy, that looks pretty amazing. Would there also be an option for it to mount it on a backplate? To make it clip-on? Sometimes you just use a backplate and tape a filtertray on it to be as small as possible....
Thnx!
Hi Timothy. Great idea to rotate any circular filter 🙌🏻. You guys are developing great products I am about to get the 19” Titanium drumsticks for my upcoming project with an Alexa mini LF... keep up the good work. Cheers!
Really Interesting. I like the fact you can add two filters for the two spaces it takes up. I have the cinema hardware Diopter tray that I use in a pinch for 138mm pola's but i like that you can add the 2nd filter in. Im not fussed on the motor gear for the pola.. maybe on a commerical where the DP wants to dial the pola in all day. But its easier just to set and forget or I'll just tell the Op to dial it in. ;)
Hi Timothy, that looks pretty amazing. Would there also be an option for it to mount it on a backplate? To make it clip-on? Sometimes you just use a backplate and tape a filtertray on it to be as small as possible.... Thnx!
Hi Rozemarijn,
Not at the moment since it's made to be used with the Misfit Kick or any other LMB matte box.
We also do have the Misfit Atom & Misfit Atom Pola+ which are ultralight matte clip-on matte boxes.
Thanks Carlos, the 19mm Drumstix definitely take a lot of weight off the rigs
Congratulations. Great stuff
yeah, if you were using it on a gimbal or in the air, it would be useful to dial it in as you go.
It can also be used as a VND if you added another pola in the 4x5.65" slot.
Wow Tim, you guys are always up to something. definitely going into the kit
Thanks Gunnar, hope you're well!
The ONE Tray is available to pre-order now.
Of course we had to drop on a Cforce mini on 😁
