filtertray with 15/19mm "feet"? filtertray By Vince on 3/2/19, 10:37 AM • 657 views We don't like using tape on glass when need to stick a filter directly on the lensbarrel. Any suggestions or people who has a solution for this? I was thinking of a 4x5.65 or 6x6 filtertray that has a 15 or 19mm adapter.
Rozemarijn On 3/3/19, 12:54 PM how about this guy! \https://abracam.myshopify.com/ Timothy Tan On 4/17/19, 2:02 AM Hi Vince, take a look at our Misfit Atom & Clash 138 ultra lightweight matte boxes. Both can accomodate two 4x5.65" filter trays and can be used with 15mm/19mm rod mounts. https://www.brighttangerine.com/store/misfit-atom-15mm-lws-kit/ https://www.brighttangerine.com/store/clash-138-15mm-lws-kit/
Thanks Timothy! Convert as an answerVince on 4/17/19, 10:01 PM
Rafael del Campo On 4/19/19, 7:41 AM Is not a really filter tray, but is a quick Nd functional solution for some special situations. When want go without clamp-in I put the filter with tape directly to mask/clamp adapter but without Mattebox, so finally is equivalent to use the filter directly with tape to te lens, but with the option to change lens quick and don’t need put tape to the filter lens by lens. Like use clamp-on but with the size of a filter plus tape.
Yep, that's pretty much what the Misfit Atom is for, you can remove the hood to make it even lighter. https://www.brighttangerine.com/store/misfit-atom/ See the second image in the gallery. Convert as an answerTimothy Tan on 4/24/19, 2:31 AM Philippe Piron On 2/23/20, 4:25 PM Vantage film does rent a system called the MB FLEX it's a 3x filter tray (available 4x5.6, 66x66) or 1 filter holder (4.5" Rd, 138mm Rd, 6" Rd) to a ULTRALIGHT-type arm and extensions, clamping onto 15 or 19mm rods. Very simple to use, great tool, designed on request of a french DOP. available everywhere Vantage Film is located: Weiden, Berlin, Prague, Paris, Brussels, Marrakech
