Hey Alvaro, I'm with the Munich based company 2EyeTec (2eyetec.com) and we offer all kinds of custom cables, also for Ronin2. So we could provide you with a Cable to connet it to the same 1B Port you are probably also using on a Ronin 2 to power a Alexa Mini. It's not in our shop yet but we already built one, so contact mail@2eyetec.com if you need one. Please keep in mind that all these ports together can supply max 8A together (14.4V). When using the Dtap Output of the Ronin2 this is (as far is I know) the same, 14.4V max 8A.
Hallo Alvaro, I had the sxt in a ronin 2 this year for a few days and had massive trouble with the internal powersupply by the ronin (some time it worked and some time not/ highspeed and raw have beed problems) but some times we could not realy figure out whats was the problem when we tried booting in proress mode. to be safe we powered the camera with an external battery. felt a bit like gambling, good luck
You can get an Arri to pTap cable DRRI 2-Pin Fischer Female to Dtap Power Cable for ARRI Alexa XT SXT Camera https://www.amazon.com/dp/B0771HVNNC/ref=cm_sw_r_cp_api_i_yMdmFb3RYXH1E
Ezra, thanks for your help
Stefan thanks!!
