Hi all @ focuspulleratwork.
I recently create and printed a teradek 500 LT/XT receiver bracket for my smallHD 503/703 to pullfocus.
I was inspired by bracket made by @Karl Walsh and the FilmFrogs Teradek Bolt Bro brackets (https://www.shapeways.com/product/6SFVMU3LH/teradek-bolt-pro-bracket-fanless-rx-for-tv-logic?optionId=23758811&li=shops).
I designed it in Fusion 360 and modelled it specifically to fit a 500LT and XT RX as i own both model of Teradek. I printed it on a flux delta. It took about 2 weeks of trial/error/redesigning until I got a working version, i run out of black fillament so i printed the definitive version in blue.
The 503 and teradek are power up by a bebob V45MCIRO and it give about 2h30 of running time (depend on the brightness of the 503)
I've attached photos to this post!
I made a really short 2pin lemo cable to power the teradek from the BEBOB vlock plate (i moved the 2pin lemo port on the plate to face the right side).
I still have an extra P-TAP to power other accesories (and one on the vlock as well).
I use the power port on the back of the 503 with a connector directly wired to the vlock plate.
There is some threaded insert to screw on the other half of the bracket.
I aimed to make a clean and compact bracket without a mess of cables.
Very nice work!
Great work👏🏼👏🏼
Love it! ❤️
Very nice! How can we get our hands on this? Are you looking into selling it?
Thanks, i can make an other one and sell it if you want.
I do think there is a market for this Jules. Personally I don’t have a 503, but I know a lot that have it. I’ll send them your way if you are interested in making some and selling it😁
Super clean
Hey Jules, great work man! I actually got my printer up and running and was starting to work on a RX bracket for my 503 myself. Since you already did such a nice job...what are your thoughts on sharing the file? =) (Totally understand if that's too much to ask!)
Looks very clean!
Did you have any heating issues with either the Teradek or the monitor with this setup though? It looks like the (usually very hot) Teradek gets pretty close to the heat sink on the back of the SmallHD, isn't it?
No issue at all with it on a 12h straight shoot, the fins on the 503 are clear from the bottom up for the air to pass trough, it's certainly not as efficient as normally but there is no problem due to overeating. I haven't yet tested it on a +20°c day.
@Jules Ferling Very cool!
Might you make something for a 703? there are times where a bracket for that monitor would be helpful (for me at least).
It's allready compatible with de 703 :) it's using the same mounting screw
Fantastic. I’d be keen to have one then... :)
I’ve no idea if the 503 and 703 have a similar screw mounting btw, apologies if this is the case and I’m being simple
I’d also love to know what thread screws you use here, as I’d likely want to have small thumb screws for quick fitting/removal of the RX Unit. Cheers!
Every screws are M3, there only 1 1/4 screw to hold the teradek.
